Mopar V8 newbie has questions
Old Jun 14, 2012 | 08:29 PM
77Adventurer's Avatar
Hi,
I recently bought an all-original '77 Dodge Adventurer SE 150 pickup. Its pretty clean considering it's 35 years old. I am unsure which small block V8 it has. I've read that there is a code stamped on the block telling what size it is. Does anyone know what/where the code is for the 318 and 360?
Also, I am thinking that the oil pump needs replaced. Is it very hard to get at? I am wanting to do as much of the repairs on this truck myself.
Thanks in advance.
Old Jun 14, 2012 | 10:05 PM
It's probably a 318 maybe a 360 ? if it is a 4bbl. Either motor requires the oil pan to be removed to access the oil pump. Why do you think the pump needs replacement ?
Old Jun 15, 2012 | 08:43 AM
It will tell you 318 0r 360 right on the side of the block.
Old Jun 15, 2012 | 06:33 PM
Ok, thanks guys.
I think the oil pump needs replaced because when it warms up, the oil pressure gauge reads almost 0psi at idle. Plus, it has a nasty ticking noise when the gauge is near 0. It's either a weak oil pump or a sticking lifter (for the ticking noise).
Old Jun 25, 2012 | 06:36 PM
moparted's Avatar
sounds more like wore out bearings
Old Feb 9, 2013 | 08:22 AM
Zoomer59's Avatar
Could be the oil pick up is plugged up.
Old Feb 9, 2013 | 01:12 PM
Remove the pan and replace the bearings and the oil pump. In actually it probably needs a rebuild
Old Feb 10, 2013 | 06:15 AM
Gorts 5th's Avatar
Smile
TVLynn is right X2 on that
i have done that repair 3 times over the years and it work out fine all three times, 2 car's and a van.
and while your in there you might as well change the timing chain and gear set and since your in there you may try a new cam and lifter set, i bet your cam is worn, then you can top it off with new intake and carb.
How many miles are on that vehicle?
Old Feb 10, 2013 | 10:48 AM
PURPLE HORONET's Avatar
They used nylon coating on the timming gear, most of the time that comes off and cloggs the oil pick up. Do a timming set also
Tink
Jun 18, 2015 03:31 AM
stephen115
Jun 4, 2010 05:31 PM
Dizzle
May 23, 2010 04:21 AM
M. Riggs
Jan 17, 2010 03:43 AM
Muswagon
Jan 2, 2010 08:49 AM
