MRL Performance stroker
Old Jan 19, 2012 | 02:07 PM
bentman's Avatar
MRL Stroker Kit (piston,rings,rods,bearings cast 4' crank 20.5cc dish pistons)
Stainless steel Bolt kit
Freeze plugs (brass)
Top end gasket kit, rear main, MLS head gaskets
Pushrods
Cam bearings
Oil Pump (std modifyed)
Windage tray Milodon
ARP Main studs w/windage tray
Damper w/bolt
Head bolts ARP
Stealth intake, bypass hose and fitting
Dist gear melling
PRW Water pump
PRW Aluminum rocker kit
Bore and hone w/plate
Main Bore/Hone (a must with new studs)
Deck (to achive good quench)
Prime, Paint, Clear Coat
Oil and filter
Dyno
Performance carb 750 w/studs and fuel line
Voodoo cam
Dist Bushing
Timing cover
Oil pan kit - pan p/u and dipstick
Timing chain and gears, double roller
Spark plugs
Breathers,pcv
Oil filter plate and stud stock
RPM Heads w/correct springs and port work
Timing chain tensioner
Rhoads lifters, variable cam timing
360 block
Flex plate
Total
Took the plunge & order a 408 stroker from MRL Performance should be ready in 12 weeks
Old Jan 19, 2012 | 02:58 PM
http://www.mrlperformance.com/index.html
Good luck. Looks like you went for the highest dollar one. I couldn't find any prices except that they say they start at $7000.00
Old Jan 19, 2012 | 03:31 PM
bentman's Avatar
well I just had a 408 got **** up on me I tried to cheap out, it lasted less than a yr.
68Dart
Mar 17, 2019 05:43 PM
lostfish
Apr 14, 2011 11:05 AM
mike639
May 28, 2009 06:58 AM
TwistedWrenches
Mar 12, 2009 07:28 PM
lostfish
Nov 26, 2007 02:54 PM
