Need help carb issue
Old Jun 29, 2019 | 07:19 AM
Moseman440's Avatar
Hey guys I’m new to mopar I have a 68 Chrysler Newport with a 440 it has been worked and has 2 4 barrel Edelbrock 650 on it I can’t get it to idle when I’m driving it’s fine. It when I try and let it idle just stalls I can’t figure out what’s wrong. Would bad gas do that it runs on a mix of cam2 and 93 I just got it this week any help please.
Old Jun 29, 2019 | 08:25 AM
Archer's Avatar
Moose -
No where near enough info. Anything from timing, vac leak or bad pump to a bad adjustment.
Since your in Port Jeff, go to http://www.longislandmopars.com/ and check out the next club meet (will be after the Chryslers at Carlise event), one of us can give you a hand. If you need a mechanic, John at JCS in W Babylon is the guy.
FYI - 2 650s on a 440 ain't the most efficient set up, and unless you have a lot of compression 93+Cam2 isn't necessary, but like I said, not enough info.
Old Jun 29, 2019 | 12:02 PM
Moseman440's Avatar
Originally Posted by Archer
Moose -
It has an electric fuel pump it’s at 5psi the timing is high will ping on straight pump gas I just bought it just don’t have the know how to tune it has Mallory distributor with vac advance I’m really thinking at this point the carbs need to be rebuilt I got it going today but if I try and get the idle below 1100 it stalls
Old Jun 29, 2019 | 12:26 PM
Archer's Avatar
Mose -
Again, we don't know what cam is in there, or anything else. 1100 rpm, without a radical cam means a vacuum leak.
5 psi doesn't require an electric pump, and may just be one more thing to worry about.
Call John at JCS Monday and have him look at it.
Old Jun 29, 2019 | 02:29 PM
Another bullseye by Archer.
Old Aug 1, 2019 | 08:01 AM
Moseman440's Avatar
Update the carbs needed to be rebuilt running a lot better now thanks
woodscrews
May 17, 2017 07:04 AM
Jvz
Oct 1, 2014 07:40 PM
garthed
Sep 5, 2013 05:58 PM
raycan2
Aug 18, 2013 09:49 PM
rwfisch
Nov 28, 2012 05:58 AM
