Mopar Forums (/forums/)
-   -   Need help with new 408 build (https://moparforums.com/forums/f81/need-help-new-408-build-22165/)
Mopar204 03-16-2019 10:48 AM
I recently purchased a 408 done by a family friend which I’m no longer in contact with. He left me with some info on what was done but I don’t think it was a properly thought out build. The car seems to be lacking power and no matter what I do and can’t get it to stop pinging under load. I was wondering what I could do without spending a ton of money on bringing the car in.
This is is the info I have on the build
-408 scat flat top stoker kit with forged pistons
-mopar m1 single plane intake
-lunati hydraulic roller cam and lifters(Advertised Duration 270/278, Lift .515/.530)
-j 202 heads ported
-holley 750 carb
-(no idea on compression) shouldn’t be higher than 11.1) I have tried octane booster with no luck
I apologize on my lack of knowledge, figured I’d ask someone with more knowledge on this stuff, thanks
RacerHog 03-16-2019 01:43 PM
Starts and Idles ok ?
Mopar204 03-16-2019 03:23 PM
Yes. It starts and idles fine. And even high rpm it’s fine just under load it pings
Iowan 03-16-2019 03:47 PM
What's you timing set at and how much total timing do you have also do you have vacuum advance?
