NO GAS TO CARBURETOR.
Old Apr 27, 2018 | 05:16 AM
Kitzy's Avatar
Iv'e got a new sending unit, new mechanical fuel pump, And I've blown out all the fuel lines. And I still can't get gas to the carburetor. It's a 383 with a carter pump and 750 double pumper carb. Does any one have any ideas on what my problem might be?
Old Apr 27, 2018 | 06:00 AM
Archer's Avatar
kit -
Most likely there a blockage in one of the lines and don't exclude the filter in your tests.
Disconnect the fuel line before the carb, put the line in a container and crank the engine to confirm.
Less likely would be forgetting to put the fuel pump push rod back, having the wrong size/worn push rod or a worn cam lobe.
Old Apr 27, 2018 | 07:43 AM
Kitzy's Avatar
When I blew out the lines I had them disconnected from the tank to the pump, And disconnected from pump to carb. The lines are clean. Like you say the push rod may need replaced. Do they wear out often?
Old Apr 27, 2018 | 08:10 AM
Archer's Avatar
Kit -
It's pretty rare. I've seen ONE become so worn it wouldn't activate the pump lever.
If you replaced the cam, make sure it wasn't designed to be used with an electric fuel pump (no fp eccentric).
Just for giggles, by pass the filter and report back.
Don't ask why I'm suspecting that ...
Old Apr 27, 2018 | 09:05 AM
Kitzy's Avatar
I'll try that, I just bought this charger, And have a lot of reciepts but not much info on the build. Holley 750 double pumper ,Mild flat tappet cam. headers, and complete rebuild. Is what I have receipts for. I'll report back. Thanks.
Old Apr 27, 2018 | 02:45 PM
Kitzy's Avatar
Took the filter out and reconnected the line, Still no gas. I'm going to pull the push rod and measure it. Also can I put my finger against the push rod and have a friend turn the engine over to see if the rod moves up and down against the cam with out smashing my finger?
Old Apr 27, 2018 | 04:14 PM
I'm not sure using your finger is a good idea...
Old Apr 27, 2018 | 07:27 PM
Archer's Avatar
Kitzy -
Yeah, your finger is probably not the best thing to use...
Even if it were safe (and it's not), you'd have no idea how much lobe is necessary to move the pump lever.
A safer option would be to disconnect the hoses from both the inlet and outlet ports and turn the engine over. You should feel a suction from the inlet and air coming out of the outlet. Unfortunately, that will only isolate the problem to the pump, but not give you the cause.
If the car came with a mechanical pump, do you still have that pump? You might be able to test it the same way. With the pump off the car, one finger on the inlet and one on the outlet, and manually pump the lever.
If the old pump behaves as it supposed to, try it back on the car and test as you did with the installed pump.
Still betting there's a blockage somewhere in the system - and that includes the carb itself.
Old Apr 27, 2018 | 08:05 PM
Safety first, use your friends finger on the pushrod and yours on the key👍
Old Apr 27, 2018 | 08:22 PM
run a hose from the fuel pump to a gas can See if it works. What happens if you prime the carb
Old Apr 27, 2018 | 09:40 PM
Kitzy's Avatar
When I prime the carb. the engine accelerates then dies when the poured gas runs out. I think I will run a supply hose to the pump from a gas can and see what I get from the outlet.
Old Apr 28, 2018 | 07:06 AM
Archer's Avatar
K -
Think about the last place you'd expect a block to be, that'll be it.
Basically you're going to have to go from the pump in both directions and see where you stop getting a suck or blow.
Seriously, I went through the same **** last year. Took a week, but it turned out to be problem with the filter inlet passage.
Old Apr 28, 2018 | 12:34 PM
Kitzy's Avatar
I put a hose from inlet of pump to a can of gas and still get no gas. So it's from the pump to carburetor. I ordered a new push rod, As mine looks very worn on one end even slightly mushroomed. It measures 2 -15/16" long.
Old Apr 28, 2018 | 05:43 PM
Archer's Avatar
k -
Sounds worn, report back when you try the new one.
Hopefully the cam eccentric is still in good shape.
Old Apr 29, 2018 | 02:02 PM
Originally Posted by Archer
k -
Sounds warn, report back when you try the new one.
Hopefully the can eccentric is still in good shape.
I believe that it can be seen if the distributor is pulled.
Old May 1, 2018 | 04:19 AM
ZEN357's Avatar
I've had bad mechanical fuel pumps right out of the box.
Old May 2, 2018 | 05:13 PM
Kitzy's Avatar
The push rod was the problem, I have plenty of gas now. It's blowing black smoke and loading up. From what iv'e seen so far I'll bet the carb. isn't adjusted any where near where it should be. It is a 383 mild cam and Holley 750 double pumper. Can anyone give me a good starting point on the adjustment? Thanks guys + gals!!
Old May 2, 2018 | 08:11 PM
Make sure the choke plate is all the way open......
Make sure the float level is just below the side bowl sight plug holes.
If the carb has 4 corner Idle air mixture screws, Make sure thay are all turned out an even amount... All the same... If it only has two, Same applys...
If it looks rich.... Check for blown power valves....
Just my 2 cents..
Old May 3, 2018 | 06:14 AM
Archer's Avatar
K -
Glad you found the problem!
Bob's description of carb tuning is fine, but if you like pictures/videos, there are a number of them on youtube.
NeverEnoughAuto
Sep 12, 2014 06:17 AM
Shan1
Sep 1, 2013 06:18 PM
Foedoe
Mar 8, 2011 07:47 AM
67coronet440
Nov 11, 2008 06:30 PM
fundadtn
Jan 17, 2007 01:44 PM
