Mopar Forums (/forums/)
-   -   Other than Australia or New Zealand Where can I purchase Valvoline VR1 10w-40 (https://moparforums.com/forums/f81/other-than-australia-new-zealand-where-can-i-purchase-valvoline-vr1-10w-40-a-14672/)
inri Apr 12, 2013 08:31 PM
Other than Australia or New Zealand where can I purchase Valvoline VR1 10w-40?
The engine builder has informed me that this is the best oil for this engine to run after break-in.
I've looked online and went to several local auto stores (Oreilly's, Kragen, Auto Zone, Napa etc.) and none of them carry the 10w-40.
One of the reasons this oil was recommended was because of its high zinc content. The car will be driven around the streets on weekends and will not be drag raced.
Thanks in advance.
TVLynn Apr 12, 2013 11:02 PM
You can use some of the diesel oils as they have more zinc. I use Rotella 10/40 in my motorcycle OR you can use Brad Penn oil Recommended by some of the big engine builders
http://www.penngrade1.com/Zinc.aspx
Quick search
The Valvoline Racing oil is labeled VR1
sfort Apr 13, 2013 05:23 AM
Zink additive
You can buy ZDDP online to add to the oil. Approx. $9.95 a bottle. Very important when running flat tappett cams.
bremereric Apr 13, 2013 08:33 AM
I run the VR1 20W50 with no problems. You can expect higher oil pressures when the motor is warmed up.
inri Apr 13, 2013 07:04 PM
Quick search Brad Penn009-7144-12PK 10W-40 Racing Oil - 1 Quart, (Case of 12) : Amazon.com : Automotive
Thanks TVLynn,
I believe this oil is great close match to what I was looking for. I appreciate the link too! :clap:
