Please Help ASAP
Old Feb 15, 2013 | 02:26 PM
mopar318's Avatar
Exclamation Please Help ASAP
i just changed my plugs and wires and my car runs rough and backfires when you step on the gas and shakes horribly when you try to drive it then stalls with a fireball shooting from the carb. Did I mess up something? I have a 85 Chrysler 5th avenue 318
Old Feb 15, 2013 | 03:08 PM
Numba ONE first "A-1" top banana question is, "how did it run" BEFORE you changed all this?
If the answer is, "better than it is now," then you either damaged a plug wire by yanking on them hard enough to damage the interior resistance material, or MORE likely, you have them in the incorrect position or firing order on the cap.
Old Feb 15, 2013 | 06:48 PM
I bet you crossed a wire. I did the same thing.
Double check it.
Old Feb 17, 2013 | 12:09 PM
mopar318's Avatar
I figured it out, I had cylinders 3 and 4 backwards, thanks for the help tho I just got on here a few minutes ago lol I havent looked at the forums since I posted it pretty much cuz I figured it out.
Craig Kozak
13
Mar 6, 2012 08:04 AM
PLYMOUTH BOB
Jan 13, 2011 11:22 AM
hellzombiex
Apr 20, 2009 11:58 AM
Crazy4Carz.Com
Apr 9, 2009 06:44 AM
blue 68 gts
Apr 9, 2009 02:06 AM
