Mopar Forums (/forums/)
-   -   Rebuilding My Carb Today, Any tips or advice? (https://moparforums.com/forums/f81/rebuilding-my-carb-today-any-tips-advice-15140/)
74Runneer Jun 21, 2013 12:56 PM
Im rebuilding my 1406 electric choke edelbrock carb today. I bought a gal of carb cleaner with a parts basket and a rebuild kit. Is there anything that i should know/ do/ be careful with? Ill go slow, take lots of pictures, and set out the parts in the order i took them off. This is my first carb rebuild so any advice would help. Thanks
TVLynn Jun 21, 2013 06:26 PM
Don't rush the job. Let it soak 6-8 hours. SPray it down with some brake cleaner to get the residue off & blow the passages out
Wear rubber gloves !!!!!!!
Coronet 500 Jun 21, 2013 07:31 PM
Spray the top gasket with WD40 for easy removal if you think you'll be going back in for adjustments.
Zoomer59 Sep 8, 2013 10:51 AM
throw the 1406 away in the garbage and invest in a Holley.
Mr.4spd Sep 8, 2013 11:11 AM
Take notes on all adjustment screws. This will give you a baseline once the carb is back on your car.
moe7404 Sep 8, 2013 12:53 PM
invest in a Holley? HA HA HA. good joke.
