Mopar Forums (/forums/)
-   -   smoke problem passenger side (https://moparforums.com/forums/f81/smoke-problem-passenger-side-18468/)
dart75 Apr 6, 2015 07:10 AM
I recently have had quite a bit of whiteish gray smoke coming from the passenger side exhaust.. I've heard it could be a warped head... or head gasket.. or possible oil rings... any suggestions?
DDodger Apr 6, 2015 09:02 AM
First thing to do is look at the plugs, and try and determine if it's oil or coolant
Next would be compression check and leakdown test Does it lose coolant?
Might be a valve seal(s)
TVLynn Apr 6, 2015 03:04 PM
do you run anti freeze ? Smell the exhaust, if it is sweet the head gasket is leaking. otherwise It could be stuck rings if it has been setting for years.. Maybe oil guide seals
Rooty Apr 9, 2015 12:36 PM
If it's blueish it's oil, if it's whiteish grey it's coolant, if it's black it's rich and if it damn near kills you when you breathe it, it's probably OK. Keep your face away from those pipes or you'll look like a mime, a chimney sweep or something that fell off the autopsy table. You've been warned!
dart75 Apr 10, 2015 07:08 AM
so all the plugs were burning good except for Cylinder # 2 on the passenger side.. it looked black and wet..
moe7404 Apr 10, 2015 10:05 AM
the 1966 and older 318s. had a very small oil drain back holes from the head. . when the hole plugs up they will smoke bad. they can be pushed clear.
RacerHog Apr 10, 2015 05:39 PM
Might have a bad spark plug.... Plug wire..... Or need a set of Valve stem seals.. Check the compression and see if it's good?...
xaza Apr 11, 2015 04:48 AM
Based on the title I was thinking open the passenger door and push them out.
RacerHog Apr 11, 2015 06:01 AM
:duck:
