Timing chain
Old Nov 2, 2014 | 11:01 AM
Gezundheit's Avatar
Timing chain
Noticed lots of slop in it.can it be changed out in place or must engine be
Removed first.regards,gezundheit.
Old Nov 2, 2014 | 01:15 PM
fivepoint's Avatar
Please include Make, Model & Year.
Old Nov 2, 2014 | 01:33 PM
Gezundheit's Avatar
Timing chain redux
Sorry about that.its a 73' dodge motorhome with a 440-3 engine.i noticed it when I replaced the rear main seal.the ground clearance is good to work under
The engine but the radiator has me wondering if I can replace the chain without
Pulling it.ugh.
Old Nov 2, 2014 | 04:01 PM
fivepoint's Avatar
I am inclined to say yes you can replace the chain and gears. As long as you have clearance to get the damper pulled off and be able see to line up the marks on the crank and cam. Even if you have to pull the radiator to do it.
Old Nov 2, 2014 | 06:20 PM
Mr.4spd's Avatar
Lining up the marks doesn't matter. The cam/crank relationship will remain constant so long as nothing moves while the chain is off.
Old Nov 2, 2014 | 08:48 PM
It can be done, removing 6the radiator just makes it easier..Remove the radiator and you can probably just sit on the ground and have it right in front of you
COMPARE the marks on the new and old gears !!!!!! I don't care how careful you are the gears will move !!!!!
Old Nov 3, 2014 | 11:17 AM
Gezundheit's Avatar
All good answers
Your answers all indicate a "no sweat" viewpoint.thats what I really wanted to
Hear and will follow up with a new chain after the winter.regards to all.gezundheit.
Old Nov 3, 2014 | 11:50 AM
moe7404's Avatar
dont for get that when the gear marks are lined up the dist rotor will NOT be pointed to #1. if you read the book it does NOT say anything about where the dist rotor will be pointed. the short story is if the gear dots are lined up you are fine.
Gorts 5th
Dec 19, 2012 04:52 PM
dynahd
Aug 8, 2011 03:26 PM
teedeej340
Dec 1, 2010 06:16 PM
roadwarrior86
Oct 11, 2010 11:40 PM
recondotexas
Apr 3, 2010 03:44 PM
