TPS/APP circuit high
Old 06-21-2018, 11:57 AM
Wirefire87's Avatar
Just did a rebuild on a 2000 318 magnum and after 3 grueling months of pain and more money than planned, I finally get to start driving it. Now I've got a P0123 (TPS/APP circuit high) and after changing the TPS and inspecting the harness the code still comes right back. I've also got a huge issue with it sucking down gas and my shift points are all jacked up. Any advice or input from the crowd?
Old 06-21-2018, 03:03 PM
Test:
Black-LtBlu = PCM - Ground
ORG-DKBLU = TPS Signal
Yellow = PMC +5Volt Ref.
Range 0.5V - 4.5V Sweep should not drop out.
Double check to make sure no wiring got pinched or broken.
Good Luck..
Bberry
03-09-2018 11:27 AM
Chrysler212
12-01-2017 09:01 AM
gwgdog66
07-26-2017 02:40 PM
ANGRY6
09-05-2012 01:58 AM
68lover
05-21-2010 08:42 AM
Quick Reply: TPS/APP circuit high
