what lifters for 360 magnum solid roller cam.
Hey guys
Is anyone running a solid roller cam in their 360 magnum? If so what lifters are you using and are they reliable? I only know if one set comp 8043-16 but Hughes engines are not 100% sure I can use them and said if they fit I will need to cut slots in the oil holes. I can't seem to find any others. Any help is appreciated Cheers maca |
The cam mfg should be able to supply you with the correct lifters...
Go with the MRL Performance.... :)
http://www.mrlperformance.com/index.html |
