Whats a 360 worth
https://cimg8.ibsrv.net/gimg/moparfo...8b2f8ac762.jpg
Lookinb to buy a 360 off a guy casting code is 4006830-360 is it worth 500? |
Did you here it run, cān you do a compression test on it?
I'd offer half that.....if it turns over! |
No. As said did you hear it run ? Mileage ? Looks to me- by the carb it came from a truck I would offer $200 It is only good for a core with out knowing history or hearing it run. IF I bought it I would plan on replacing every gasket & freeze plug and do a valve job....
Block is 1976-86.
