Mopar Forums (/forums/)
-   -   Windage Tray/ Gasket Combo (https://moparforums.com/forums/f81/windage-tray-gasket-combo-20646/)
fivepoint Aug 26, 2017 06:23 PM
I had to change the rear seal in my 440. While searching Summit for gaskets, I found a windage tray with gaskets molded on it. Summit Part number
SUM-G2339. This worked great. I don't know how long these have been around but it will be using these every chance I get. The pan does not leak and the bolts lined up and went in with ease. No sealant is required and it is reusable.
John Van Aug 27, 2017 04:34 PM
The Idea sounds good, the pan itself, is it really nylon? The sum-g2339 is for a stock crank.this one is for a stroker crank 4.150
https://www.summitracing.com/parts/sum-g2340
