would the crankshaft be the same in both a 69 and 71 440 block
I have a 69 hp 440 engine. Would the crankshaft be the same as one in a 71 440 block?
Only difference would be Steel or Forged... But yes... Its the same... only thing to watch is if the end is made for a automatic or a 4 speed... Some machining is needed some times... :)
It opens other problems as too balance between the cast & forged... Personally I would ONLY use a forged crank
| All times are GMT -7. The time now is 01:44 AM. |
