Mopar Forums (/forums/)
-   -   WTF (https://moparforums.com/forums/f81/wtf-19522/)
Drag Pak Jun 27, 2016 04:35 PM
WTF
1 Attachment(s)
Will this still work? A friend just pulled this on the side of the road.
I have NEVER seen this happen before!
Iowan Jun 27, 2016 04:49 PM
Let's hear it for the Chinese parts!
It looks like it's a fairly new part.
Coronet 500 Jun 27, 2016 05:09 PM
Hopefully no broken bits fell inside, I think I'd take the front off and have a llok at the other stuff in there.
Drag Pak Jun 27, 2016 05:09 PM
My feeling exactly. New and less than 120 mi.
Told him to go to dealership for Mopar piece.
RacerHog Jun 27, 2016 06:02 PM
Installed Wrong ?????????? ^^^^^^>>>>
Drag Pak Jun 28, 2016 06:22 PM
The difference
1 Attachment(s)
This difference must be the culprit? Old (lower) versus new. Weak construction (lever) at best! And different part numbers!
RacerHog Jun 28, 2016 07:49 PM
Top looks like the 8 Cylinder one?
Drag Pak Jun 28, 2016 08:15 PM
Bob, the top one is the parts store (warranty)replacement for the failed one, just to get the car home. It is the same visually and part number for what was installed and failed. The bottom is what came out prior to the rebuild. I see Summit and Mancini sell both types, but the cheap ones are like the broken one.
RacerHog Jun 29, 2016 09:44 PM
Wow... Just goes to show, you just dont know what your getting anymore? All this off shore stuff is getting worse by the minute....
Drag Pak Aug 22, 2016 08:00 PM
Well, long story short. Apparently there is a different pump (upper pump in photo) for the newer "A" engine and the part numbers cross.
