Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   130 tooth flywheel or 143 tooth flywheel?? Help (https://moparforums.com/forums/f82/130-tooth-flywheel-143-tooth-flywheel-help-11812/)
69charger71duster Mar 2, 2012 09:24 PM
Hello people....
Ok,I have another question.I am putting a a-833 transmission in my charger 440.the bell housing number is 2892626 39028.I wanted to know if the flywheel I have will work with that.itīs a 130tooth flywheel with 6 bolt pattern.the guy who I bought the trans from,gave me the flywheel along with it.The trans was from a 69 roadrunner and he believes that this was the flywheel that came with it .....but not 100% sure.Or can it use both 130tooth and 143tooth with that bell housing?the flywheel looks like it had a 10.95 inch clutch on it....
Help me please.
Thanks
71duster69charger
bremereric Mar 3, 2012 12:00 PM
I can't answer your question and if no body else does contact Brewer's Performance on Monday.
http://www.brewersperformance.com/
