1965 Fury III 727 transmission fluid
I just purchased a 65 Fury and was wondering what kind of tranny fluid I should use
Dex/Mercon is probably your best bet.. Dex II superseded by Dex III, superceeded by ATF 3, superceeded by ATF+4
Make sure it say's for older Chrysler's on it before you buy it.....
But if all else fails.... Put Ford F type in there...It will be fine... Just my 2 cents... OK boys.... Bring it.....:argue: |
| All times are GMT -7. The time now is 04:01 AM. |
