1976 D100 question.
I have an automatic trans in my truck which needs a steering column. I have another 76 but it is three speed on the column. Will that column work at all on the automatic?
Just what are you asking?
(Post 138295)
If you need an auto that's what you need.
(Post 138297)
I'm not sure I understand what you are looking for.
(Post 138306)
So you want to use a column shift use what you you need.
You could use it if you went to a floor shifter. Otherwise I think any cordoba Volare, Van auto column should work or could be adapted very easy
| All times are GMT -7. The time now is 11:09 PM. |
