408 Stroker compatibility
What up guys! I have a 1999 Ram 1500 with a Magnum 5.9L 360 2WD. I've been wanting to beef it up and was looking for information on a carbureted 408 Stroker motor I'm looking to throw in it.
https://www.jegs.com/i/ATK-Engines/059/HP46C-MAG/10002/-1?CAWELAID=230006180040132636&CAGPSPN=pla&CAAGID=4 4693592161&CATCI=pla-224362047431&catargetid=230006180039220355&cadevic e=m&jegspromo=nonbrand&gclid=EAIaIQobChMIxpyB8YTq3 wIVQ8DICh2EwQUlEAQYCSABEgI0pfD_BwE
i'm lost when it comes to info such as a 1.compatible performance transmission, 2.rear end, drive shaft and 3.wiring harness if need be.
If anyone has any tips on what will bolt up to the Chrysler 408 Stroker motor above! I will greatly appreciate it!
This is my first engine swap/build. So any other suggestions I'm open to! feel free to chime in with anyone's expert opinion!
Getting your transmission to work and dash, charging system etc. will be the challenge because they all work off the computer you will not be using. I'm sure there is a way to make everything work but it's over my pay grade.
