408 Stroker compatibility
Old 01-15-2019, 06:06 PM
99 Ram's Avatar
What up guys! I have a 1999 Ram 1500 with a Magnum 5.9L 360 2WD. I've been wanting to beef it up and was looking for information on a carbureted 408 Stroker motor I'm looking to throw in it.
https://www.jegs.com/i/ATK-Engines/059/HP46C-MAG/10002/-1?CAWELAID=230006180040132636&CAGPSPN=pla&CAAGID=4 4693592161&CATCI=pla-224362047431&catargetid=230006180039220355&cadevic e=m&jegspromo=nonbrand&gclid=EAIaIQobChMIxpyB8YTq3 wIVQ8DICh2EwQUlEAQYCSABEgI0pfD_BwE
i'm lost when it comes to info such as a 1.compatible performance transmission, 2.rear end, drive shaft and 3.wiring harness if need be.
If anyone has any tips on what will bolt up to the Chrysler 408 Stroker motor above! I will greatly appreciate it!
This is my first engine swap/build. So any other suggestions I'm open to! feel free to chime in with anyone's expert opinion!
Old 01-15-2019, 07:02 PM
Getting your transmission to work and dash, charging system etc. will be the challenge because they all work off the computer you will not be using. I'm sure there is a way to make everything work but it's over my pay grade.
Old 01-15-2019, 10:55 PM
I would look into doing a 408 stroker with using your Magnum motor It is not going to be cheap. Also a stand alone EFI system
jdcarnathan
10-05-2011 10:32 AM
xaza
07-01-2011 01:17 PM
chrint
04-16-2011 06:26 PM
bentman
09-19-2010 05:06 PM
Doc
09-17-2008 05:10 PM
Quick Reply: 408 Stroker compatibility
