440 nv4500
Old Sep 19, 2021 | 07:58 PM
Bracrgr's Avatar
440 nv4500
I'm currently swapping an nv4500 into my 1976 Ramcharger. I have almost everything figured out except the Fork and throw out bearing setup. I'm using lakewood bellhousing part #15335. I'm going to try calling them 2maro to see if they have any suggestions or tips but. I tried to get a hold of em before and they took forever to answer. Just curious if anyone has done this swap already. Thanks.
Old Sep 19, 2021 | 08:01 PM
Bracrgr's Avatar
Old Sep 19, 2021 | 08:18 PM
Looks like fun, how do you keep U joints in it? I had a 77 short box with a 5" lift that would kill front U joints.
Old Sep 20, 2021 | 06:43 AM
Bracrgr's Avatar
Thanks, she's alotta fun. So these trucks come with a short driveshaft from the factory up front. When you lift them the pinion angles become too steep. Even with a double cardon joint at the tcase. This truck has a np203/205 doubler in it so it adds a little length to it. Also the front end has been stretched forward quite a few inches as well. This helps lessen the angle. I don't really know how much lift I've got cause the springs are actually 52" rears off of a blazer.
Old Sep 20, 2021 | 08:42 AM
I only use Spicer joints, I was lucky to get 2k out of the diff joint.
If I had a long drive I'd pull the front shaft and lock in 4wd.
It had 33s on it with 3.55s, it was the best truck for pulling my Plymouth, it pulled better than my new at the time 95 Ram 1500 4w1500 with the same gears and 31s on it.
Old Sep 20, 2021 | 03:38 PM
Bracrgr's Avatar
Yeah, they're lots of fun once you find the right setup.
I've just used the parts that come with my new driveshafts. I believe they're napeco. Spicer does make really good parts tho. Also I spoke with someone from Holley and they told me I can use the clutch fork from a dodge setup. So I will use that
87powerram
Sep 20, 2019 11:35 AM
sharp89
Dec 4, 2017 04:33 PM
440truck
Dec 28, 2012 03:17 AM
Hypar
Nov 2, 2010 03:28 PM
Hypar
Sep 10, 2010 05:22 PM
