| Snoblor |
Aug 16, 2013 02:11 PM |
46RH trans part #series
I'm looking to find a 46RH transmission. Does anyone know what the part number series (stamped on the drivers side above the pan) would be for all years that it was made? The part number I have to check against is a 52118328 but doesn't match anything in the junk yard. I'm building a truck, so don't have a trans to reference. So if I had a reference list of the entire series of numbers, I could check to see if I'm pulling the correct trans. Or is there an easier way, I know about the two and three wire plugs, but would like to be 100% sure before I go through all the work to pull it out. Thanks in advance for your help!
