4x4 problems and need some info
Old 02-13-2018, 07:26 PM
majormopar's Avatar
I have an 86 dodge w150 4x4 and the four wheel drive is all messed up and id rather have a 2 wheel drive so my question is can i take the front differential out and put a front end from a 2 wheel drive truck under mime? Im not sure if the frames are the same and is a direct bolt in swap plz help
Old 02-13-2018, 08:17 PM
The frames are not same.
Old 02-14-2018, 08:11 PM
It can be done... It's just not a direct swap out / Bolt in...
Old 02-16-2018, 06:28 PM
afastcuda1970's Avatar
It would be easier to swap the whole frame.
Old 02-18-2018, 05:22 AM
xaza's Avatar
If you have manual locking hubs then there is really no need to swap the axle because when not locked the wheels spin free from the internals so there is not the extra resistance of turning the gears. The question then becomes the transmission, is there a benefit for him to swap out the transmission to the 2wd version? Do the trans mounts match up? What is messed up on the 4 wheel drive?
Old 06-24-2018, 07:19 AM
mapman's Avatar
This is an older thread but I will weigh in. The frame rails are the same but the cross members are different. The parts are riveted in place and have to be cut out, new holes drilled and bolted back together. I did the opposite building a 4x4 from a 2wd. It is a fun project but you will want a complete chassis to locate everything. I bought a wrecked w250 with a bent frame and transferred everything to my d150 20 years ago and am still using it.
Rob
Old 06-25-2018, 04:26 PM
Trail Duster's Avatar
4x4 vs 2x4
Why?! Fix the 4wd...2wd is useless in snow and off road. I don't even look at 2wd anymore. Fix what you got and learn from it and leave everyone else stuck in your dust! LMAO
Doug613
06-03-2018 05:02 PM
DeborahBlair
03-29-2013 02:26 AM
scotts74birds
09-01-2011 03:15 AM
Iskone
08-18-2009 01:49 AM
lonewolf273
11-19-2008 06:56 PM
Quick Reply: 4x4 problems and need some info
