Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   545rfe transmission (https://moparforums.com/forums/f82/545rfe-transmission-11138/)
Rojo Benavidez Nov 28, 2011 11:10 AM
545rfe transmission
bought 2004 360 with 2600 miles on it going to make a engine swap wanted to know if my 545rfe bolts up to motor my first engine swap
bremereric Nov 28, 2011 12:02 PM
Good question..I would like to know also.
TVLynn Nov 28, 2011 04:04 PM
Not familiar with your swap. I would say your 360 magnum combo
You need to convert to a carb setup or A digital Accel fuel injection setup Or somehow adapt the computer???
You need to deal with your electronic trans controls and No speedo drive ???
Deal with the motor position, the rear trans mount needs to be modified - moved back I think or the motor will be to far forward..
mr340 Nov 28, 2011 04:33 PM
Ummm, what type of vehicle are we talking about here?
BTW, Welcome.
Rojo Benavidez Nov 28, 2011 07:15 PM
i have a 2004 dodge dakota quad cab with a 4.7l v8 and i am planing to swap it for 5.9 360 that i got from a van 2004, i am going to leave it fuel injection going to get some to rewire the engine and clean up my engine bay free of wires. my question is if its the same bolt pattern to bolt up my 545rfe to that 360 i know the r/t comes with a 46re 4 speed thanks for you alls help!
https://moparforums.com/forums/membe...6-img-0525.jpg
La595team679 Oct 2, 2023 10:05 PM
Im wanting to know the same thing, everywhere i go online its all backwords or just nothing on bolting up a 360 magnum up to a 545rfe auto trans.
La595team679 Oct 2, 2023 10:13 PM
Engine and Tranny swap+Build
im doing a engine swap in a 2000 Mitsubishi Montero Sport Limited, it has the 3.5l v6 and i want to put a 360 magnum in it with a 545rfe automatic transmission. All i want to know before i even start spending any money is if the 360 Magnum and the 545rfe Transmission are compatible. Ill also be boosting it, of course the 545rfe will be staged to at least 3 if i can id go straight for stage 5. Ill put a Procharger in it,
RacerHog Oct 3, 2023 04:35 PM
I am not sure...
Lostviking Oct 4, 2023 01:53 PM
The short answer is yes the 4.7 and the trans will bolt up. There is a bolt at 3 o'clock that doesn't line up. You can modify so you get a bolt there or just leave it out.
