64 Fury axle shaft
I am new to the forum, I did a search but could have missed a previous post if this has already been discussed I apologize. I was working on the rear brakes on my newly acquired 64 fury, using a puller to remove the outer flange and drum. Unfortunately it split the outer end of the axle shaft. I have not had any luck finding a replacement.
Does anyone know where to get a replacement shaft or a shaft that will convert it from the 2 piece to a 1 piece design? Any help would be greatly appreciated. Thanks, Nathan |
I think Summit has one piece shafts but I think you need to cut it to length.
Mark Williams Quick Performance strange All have what you need but if you can find a mone piece shaft for a later later that will work. I've been assuming you have a 83/4 axel something you need to know. I would also try usedpart.com... |
(Post 158610)
Desert Valley Auto Parts in Arizona..... Maybe up to 1965.... Is that the Axle with the adjustable bearing flange to the outside of the bearing ?????
(Post 158614)
I believe 64 was the last year for this design. I was wondering if anyone knew if any later years are a direct replacement axle shaft for this style |
I forgot about the bearings, try parts for a 65 Fury, the last time I needed an axel I went out to my local yard and picked one up.I was looking to replace two big bolt pattern axels from a big Chrysler with the 5 on 4.5 bolt pattern. They had racks of mopar axels so whith a tape measure I picked out what I needed...
I would think there would be a salvage yard you can call locally. |
(Post 158617)
| All times are GMT -7. The time now is 03:11 AM. |
