Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   727 transmission bolts to engine? (https://moparforums.com/forums/f82/727-transmission-bolts-engine-18270/)
inri Jan 31, 2015 01:28 PM
Hello,
I misplaced all the transmission bolts to the engine when we moved. I'd like to know where I can find a replacement set, preferably online. I think there's like 7 or so bolts.
The 727 will mount to a 440.
Lastly, will the bolts also mount to a hemi?
thank you.
TVLynn Feb 2, 2015 04:15 PM
Hemi / 440 would use the same bolts. Any junk yard should have the bolts. Use any from a 727/904/518/ 42RE etc.. to piece together what you need.. all use the same bolts.. You could use some generic grade 8 bolts but will need to use flat washers too.
Gorts 5th Feb 2, 2015 05:23 PM
Any of the online parts companies ..summit racing . Jeggs. PACT.COM will have wat you need
RacerHog Feb 2, 2015 07:28 PM
CAll Bob... He has some to send you...
http://www.bobmazzoliniracing.com/
inri Feb 11, 2015 10:00 PM
I've seen this question come up while "googling" it... Here's the answer:
ARP Bolts 145-0902 +/- $20
They are beautiful looking bolts.
