Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   78 D150 posi-track rear end? stock? (https://moparforums.com/forums/f82/78-d150-posi-track-rear-end-stock-13468/)
oldiebutgoodie Oct 10, 2012 08:02 AM
Heya guys, Me and the son were dialing in the timing on the 78 late yesterday, and when the son took off, he left two nice pretty black marks behind him!! And I was wandering if anyone knew if these trucks came stock from the factory with posi-track rear ends?? Because this one sure has got one!! no limited slip differential on this one! I was just curious if anyone knew if this was stock protocol on these trucks back in the day off the floor ???
78D200 Oct 10, 2012 09:21 AM
I know that you could get a 3/4 ton with one as an option (Dana 60 with a trac loc/limited slip/sure grip/posi - all the same thing).
Could it have one? Yeah but if it does, I'd be someone swapped it in. At the same time though, it could be open and both tires just happen to have lost traction and spun, I've done that before on my J10 when I had it.
oldiebutgoodie Oct 10, 2012 09:41 AM
Originally Posted by 78D200 (Post 92572)
I know that you could get a 3/4 ton with one as an option (Dana 60 with a trac loc/limited slip/sure grip/posi - all the same thing). huh,I did not know that limited slip was the same as posi!! thanks for the subtle correction on that..
Yea, I'm defiantly leaning toward someone messing around with it in the past..Its been a long time, but I remember my Dad used to weld something together on the gears or something to make em posi. (he did that on a old 72 camaro he had back in the day?) thank you sir..
78D200 Oct 10, 2012 12:24 PM
He would have welded the spider gears and side gears together and possibly to the carrier. This would make the rear axle act as though it had a spool in it.
TVLynn Oct 10, 2012 12:27 PM
The sure grip was an option. If it was welded you would know it the first time you turned a corner
oldiebutgoodie Oct 10, 2012 08:30 PM
I gotcha now...
oldiebutgoodie Oct 10, 2012 08:32 PM
Well, this trk does not chirp tires turning corners...that makes total sense to me now...so this trk is probably LSD then.... also makes sense why my Dad only ran that old 72 camaro down the track in a straight line...lol...Thanks TVLynn
Gorts 5th Oct 11, 2012 05:45 AM
always a bonus find
posi can be dangerous be carefuller in slick conditions believe u me ive had my share of close calls
oldiebutgoodie Oct 12, 2012 04:03 PM
Fun, Fun
Originally Posted by Gorts 5th (Post 92624)
always a bonus find
Yea me to, but its fun though... Especially after a fresh rain on the back roads...Yeha
