8.75 true grip
Does anyone know where I can find an 8.75 true grip clutch? I have a 741 open carrier and i want to get both wheels spinning but i cant find just the clutch. I can only find 3rd members with it already installed. Any help would bve much appriciated.
It is called a SURE GRIP...And you will have to change the CARRIER you cant just put a clutch in a open rear differential...The SURE GRIP CARRIER will have the clutches or cones in it...If you are using this car for track use only you can put a spool in it which is much much less money but it cant be driven on the street...Bill
741 is small pinion, why not get a 742 or a 489 carrier much stronger BUT there are newer types of sure grips available for the 8 3/4
