89 D150 Converter wont lock up
Rebuilt valve body and new lock up solenoid that is on valvebody.
Could speed sensor be a part of the problem or something else?? Or am I replacing the converter...? |
Check for a TCC Fuse...... Also check the OD in and out switch and make sure it's working.
89 D150
Where would the TTC fuse be? All my fuses are good. I had a 91 that had the OD button on dash. This one does not...
Thanks. |
Oh...Your has the "D" with the circle around it?
Could be the speed sensor. Check to see if it's getting Signal... Should come from the Computer. |
Doesn't even have that.... But It does shift to 3rd but no lock up.
3.50 gears. But shouldn't be screaming at 65,0.... |
Vin states 4 speed overdrive.....
| All times are GMT -7. The time now is 02:42 AM. |
