904 hard driwing when cold
Hi
I have a 1970 challenger with 340 and 904. When the car is cold the transmission have a hard time to make the car move, I need to give high throttle to make the car move. When engine and transmission is hot, it works perfect. Is it time for a new transmission ? Regards Tony |
during it's life someone transplanted a 340 into your car.... THE factory NEVER put a 904 behind a 340 motor. Your 904 probably has leaking seals.
Might be something as simple as fluid and filter, I've had the filter plug up and not pull fluid when cold.
Hi
Yes it is born with 318. I will try the filter first Thanks. What o rings are you meaning ? Regards Tony |
Tony -
Do a full tranny tune-up first. New filter, fresh fluids - including what's in the torque converter, if possible. Making sure all the lines are open by flushing them, if possible. When you drop the filter, you might want to drop the valve body as well and see how the stuff on top of it looks. Checking/adjusting the bands might be a good idea, since you're there. Sorry, never worked on a 904, assuming the set up is similar to a 727. Archer |
Tks.
When I read about adjusting the rear band, I can see some places they want to turn back the screw 4 turns, and some other places only 2 turns ? What is correct? Tony |
Start the car.... Put it in neutral and for a couple minutes on warm up.... Then put it in drive.... That should help with the common "Morning Sickness"....
It is also referred to as Converter drain back..... :) |
Hi
Is there a way to solve the problem? (Converter drain back) Regards Tony |
Originally Posted by Rute66
(Post 131175)
Hi
Is there a way to solve the problem? (Converter drain back) Regards Tony One of my old 727's we took the valve body apart and use some 2000 or finer grit wet sandpaper on all the valving to remove any varnish buildup and possible burrs on the valves. Especially the torque converter control valve. This procedure cured this one. On my current 727/904 race transmission, I found one of the hooked steel seal rings on the back of the pump badly worn. Once I replaced the hooked steel ring - problem solved. $0.02 |
Yes.... Installing a new pump takes care of the problem... But at that point you might as well freshen up the trans complete....
Just My 2 cents.... :) |
Tks.
Regards Tony |
727 truck tailhousing instead of 904
Hi
I have a 727 SB with truck tail housing. I can see the transmission is longer so I need another yoke and driveshaft. I can also see it missing mounting holes for the shifter rod bracket, can I use the tailshaft from my old 904? Do I need anything else? Regards Tony |
| All times are GMT -7. The time now is 04:53 AM. |
