Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   A727 kickdown linkage (https://moparforums.com/forums/f82/a727-kickdown-linkage-12495/)
kcgregg Jun 5, 2012 01:47 PM
Does anyone have any recomended sources for some complete A 727 kickdown linkage? Going to poke around at a swap this weekend but want a backup plan in case I can't find something OEM.
Thanks
Gregg
70Coronet Jun 5, 2012 02:44 PM
Havent used it myself but I'm pretty sure I have seen some cable setups through lokar-with good reviews might be worth checking out
bremereric Jun 5, 2012 03:44 PM
Back up plan is a kickdown bracket and cable from Bouchillon Performance.
http://www.bouchillonperformance.com/BPEtkdc.asp
http://www.bouchillonperformance.com...emiINSTALL.jpg
ravenfan Jun 6, 2012 10:07 PM
I'm trying to adjust my kickdown on the new six pack install on my dart. I saw one on ebay, looks just like mine and even has threads for adjusting the rod down to the tranny.
robertstjean Jun 13, 2012 01:43 PM
727 kickdown
I have the kickdown and throttle control cable from Bouchillion and it works great. You have way more adjustment for your shifting pattern than the OEM.If I remember it was about $100 or close to it....Good luck
