Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   can anyone ID this tranny for me??? (https://moparforums.com/forums/f82/can-anyone-id-tranny-me-9855/)
jjg73 Jun 16, 2011 02:41 PM
its quite common i sure i just wanna know the exact name of it. its a 4 speed with short tail.
http://i156.photobucket.com/albums/t...3/DSC00144.jpg
http://i156.photobucket.com/albums/t...3/DSC00143.jpg
http://i156.photobucket.com/albums/t...3/DSC00142.jpg
mr340 Jun 16, 2011 04:12 PM
A-833 looks like an A-body unit, on the flat pad on the right side there should be some numbers, they will help determine what year it is.
Coronet 500 Jun 16, 2011 05:04 PM
Face to tail end.
A+F= 23.2"
B+E= 27.0"
Looks like 23 spline.
jjg73 Jun 17, 2011 03:58 AM
looks like it, thank you all for the help!!!
440roadrunner Jun 17, 2011 08:10 AM
Also, I don't know how to tell an overdrive unit "by looking." One easy way is to realize that 3-4 gear is "reversed." Since there is no shift lever on the 3-4 (front) shaft, take a wrench and rotate the shaft CW, which is into 3rd for a conventional 4 speed, and OD for the "OD" unit. Then rotate the input shaft ONE turn and watch the output.
A conventional 4 speed will rotate the output LESS than one turn (3rd)
An OD unit will rotate the output MORE than a full turn
(Shifting the lever COUNTER clockwise will put EITHER box into "straight through" gear, which is 4th for a conventional box, or "3rd" for an OD box)
jjg73 Jun 18, 2011 05:29 PM
thanks for all the info. i am in the process of looking for a speedometer cable for it as well. i just got off the phone with Summit and they mentioned a great mopar parts site but i didnt get the name, i misunderstood it on the phone. like i mentioned in previous posts, my car was used for drag racing at the local track back in the 90s and since then the rings have become junk. i have the engine out right now rings will be in monday, but since i got it out i figured it would be cake to put the speedo cable in with no obstructions in the way. i have not been able to afford to put time and money into a nice mopar before but now i have the time and never really surfed the net to find good sites for parts, so if anyone knows a site, or many, please let me know!!!
