Conversion U-joint between driveshaft and differential?
Hi guys,
I have 1973 Charger and want to change U joints but can't determine which one is between differential and driveshaft. The one between driveshaft and transmission is NEAPCO 2-3050 (7290 Detroit/Spicer 1330) http://www.thirskauto.com/vehicle-re...ea_2-3050.html The other, between differential and driveshaft, is mystery to me :) Here you can see u-joint dimensions. http://s28.postimg.org/rtbg6712h/IMG_5524.jpghttp://s28.postimg.org/irwwsl355/IMG_5527.jpghttp://s28.postimg.org/47ftxr86h/U_Joint_Charger.jpg Cap diameters are 1.078" and 1.063", and I found these: http://www.summitracing.com/int/parts/mog-457 http://www.summitracing.com/int/parts/mog-319 Problem is that other dimensions don't fit, I mean on u-joint width/height. My old u-joint is 2.44" x 3.15" First one from Summit is 1.125" x 3.622" Second from Summit is 1.125" x 3.218" So, what do you think, what u-joint I have :) |
What sort of rear axle? "All Mopar?" Or adapted that might be out of Ford, etc? like a Spicr, etc?
There was one odd joint about 66? or so in the spicer rear ends |
That size sounds like it might have been upgraded.... I Dont have time at the moment to look for the cross reference for you. But check Precision u joint spec and or the Dana/Spicer spec catalog....
My first guess was 7260/1310.
Is the 3.15" measurement inside between the clips? Look up Neapco Catalog pdf, and you'll find all dimensions, I had a quick look and couldn't find 3.15". |
Yes, 3.15" is between the clips and I couldn't find any u joint with that width.
I solved the problem and it was my mistake while I measured the joint, it is DETROIT 7260 - SPICER 1310 :)
Thanks guys. |
Cool Beans...:)
