Drive train vibration
Old Jun 24, 2013 | 05:25 PM
boouuks's Avatar
I have a 1967 Dodge A100 Van. When I take off it has a small vibration until it gets going and then quits and starts again when it shifts to second and as the rpms go up it goes away and starts again when it shifts into third. It is worse when it is pulling in each gear. I can also feel it when I let off the accelerator but not as bad. I took it to a trany shop and they said it was not the torque converter, but somewhere in the drive line. Any ideas?
Old Jun 24, 2013 | 05:48 PM
Sounds engine related does it do it in neutral
Old Jun 24, 2013 | 05:55 PM
moe7404's Avatar
U-joints. my dad always said check the easiest and cheapest things first.
Old Jun 24, 2013 | 07:37 PM
Yes check easy first, have a look at the trans mount too.
Old Jun 25, 2013 | 08:18 AM
boouuks's Avatar
It does not do it in neutral, either standing still or rolling. When it is neutral everything feels normal.
Old Jun 25, 2013 | 08:22 AM
boouuks's Avatar
Tranny mount looks good, however, these transmissions "hang" instead of sitting so I can't do much to check it without removing it. The rubber in the "eye" looks solid and intact but that's about all I can tell from just looking at it.
Old Jun 25, 2013 | 08:23 AM
boouuks's Avatar
The Ujoints seem tight, no slop.
Old Jun 25, 2013 | 12:14 PM
U joints don't necessarily have to have slop If one of the U joint bearings freezes up. Also check the differential pinion nut make sure it is tight. Take it out to check joint movement
Old Jul 2, 2013 | 05:45 PM
boouuks's Avatar
Smile Vibration gone
The vibration is gone....... The drive shaft had been installed with the u-joints out of phase. I took it loose, rotated it one spline, put it back together and "bam" the vibration is gone, gone, gone.
Thanks for your input, it really pays to look for the simple things first, not to mention the cheapest things..
Old Jul 2, 2013 | 06:00 PM
Are you talking about the fitment in the trans or do you have a two piece drive shaft
Old Jul 3, 2013 | 07:37 AM
boouuks's Avatar
Two piece drive shaft.
Mopar_Fan
Nov 6, 2010 12:55 AM
jay39452
Jun 8, 2010 06:34 AM
deadkelly
Jan 23, 2010 06:56 PM
80VDuster
Jul 26, 2008 11:58 PM
bschubarg
Apr 10, 2007 07:08 AM
