Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   Drive train vibration (https://moparforums.com/forums/f82/drive-train-vibration-15161/)
boouuks Jun 24, 2013 05:25 PM
I have a 1967 Dodge A100 Van. When I take off it has a small vibration until it gets going and then quits and starts again when it shifts to second and as the rpms go up it goes away and starts again when it shifts into third. It is worse when it is pulling in each gear. I can also feel it when I let off the accelerator but not as bad. I took it to a trany shop and they said it was not the torque converter, but somewhere in the drive line. Any ideas?
TVLynn Jun 24, 2013 05:48 PM
Sounds engine related does it do it in neutral
moe7404 Jun 24, 2013 05:55 PM
U-joints. my dad always said check the easiest and cheapest things first.
Coronet 500 Jun 24, 2013 07:37 PM
Yes check easy first, have a look at the trans mount too.
boouuks Jun 25, 2013 08:18 AM
It does not do it in neutral, either standing still or rolling. When it is neutral everything feels normal.
boouuks Jun 25, 2013 08:22 AM
Tranny mount looks good, however, these transmissions "hang" instead of sitting so I can't do much to check it without removing it. The rubber in the "eye" looks solid and intact but that's about all I can tell from just looking at it.
boouuks Jun 25, 2013 08:23 AM
The Ujoints seem tight, no slop.
TVLynn Jun 25, 2013 12:14 PM
U joints don't necessarily have to have slop If one of the U joint bearings freezes up. Also check the differential pinion nut make sure it is tight. Take it out to check joint movement
boouuks Jul 2, 2013 05:45 PM
Vibration gone
The vibration is gone....... The drive shaft had been installed with the u-joints out of phase. I took it loose, rotated it one spline, put it back together and "bam" the vibration is gone, gone, gone.
Thanks for your input, it really pays to look for the simple things first, not to mention the cheapest things..:dance:
TVLynn Jul 2, 2013 06:00 PM
Are you talking about the fitment in the trans or do you have a two piece drive shaft
boouuks Jul 3, 2013 07:37 AM
Two piece drive shaft.
