Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   Gears change nightmare (https://moparforums.com/forums/f82/gears-change-nightmare-19449/)
josehf34 May 29, 2016 03:33 PM
3 Attachment(s)
I'm doing a gears change on my '74 fury but is starting to be a real nightmare!
According to the differential cover bolt pattern my axle is an 8.25 but I'm starting to think that maybe isn't due to so much problems
https://moparforums.com/forums/attac...1&d=1464560467
The stock gears were 2.83 (i think...) and the new gears are 3.55, the new pinion and gear are a kit sold by Richmond Gear Excel and the installation kit is a Motive Gear super kit.
The pinion and gear are successfully installed but now I've a problem with my carrier bearings, apparently the new bearings doesn't fit in my axle housing (see second image attached), I checked the list parts of the installation kit and everything is correct, the bearings part numbers are correct so I don't know why them doesn't fit
The second problem is that one of the adjusters in my axle is broken (see third attached image), I mean, when I disassembled the unit it fell broken in my hand. Is it easy to find? can I buy one or will be needed to buy a pair?
Iowan May 29, 2016 03:54 PM
Send pictures of your wife!
Coronet 500 May 29, 2016 04:23 PM
Chrysler 8.25" Axle Parts, Gears, and Upgrades
Axle Specifications:
Ring Gear Diameter: 8.250
Diff Cover Bolts: 10
Ring Gear Bolts: 10
Axle Spline Count: 27 / 29
Axle Shaft Style: C-Clip
Pinion Diameter: --
Pinion Splines: --
Pinion Support: No
Carrier Breaks: 2.47* / 2.56
*2.54 w/ e-locker
Dropout Carrier: No
Torque Specifications:
Pinion Preload New: 12 to 15 in-lbs
Pinion Preload Reused: 6 to 8 in-lbs
Ring Gear Backlash: .006" to .010"
Ring Gear Bolt Torque: 55 ft-lbs
Carrier Bearing Caps: 60 ft-lbs
Popular Applications:
Dodge Charger 1968 - 1975 Rear
Dodge Dakota 1987 - 2004 Rear
Dodge Durango 1998 - 2004 Rear
Dodge Ram 1500 1994 - 2004 Rear
Dodge Ram 2500 1997 - 2001 Rear
Jeep Grand Cherokee 2005 - 2010 Rear
Jeep XJ Cherokee 1991 - 2001 Rear
Axle Images:
Axle Details
The Chrysler 8.25" axle is found in many Dodge and Jeep vehicles and comes in several different configurations. The 2005 and new Chrysler 8.25" axle features larger 29 spline axle shafts and uses metric ring gear bolts. All other models have 27 spline axle shafts. The easiest way to identify the axle is to check for 10 cover bolts, an oval shaped cover, and a fill plug just below the centerline. You might also be able to find the ID tag wrapped around the passenger side axle tube with the axle ID and gear ratio listed on it.
josehf34 May 29, 2016 05:35 PM
lol, why? give me a good reason and I'll do it
Where can I buy the broken adjuster online? I've been looking for it on ebay but there's only a pair used for sale
RacerHog May 29, 2016 06:56 PM
Doctor Diff or LPW Racing Products. Mancini Racing... Bob Mazzolini Racing...
Iowan May 30, 2016 05:03 AM
"My wife yes, my dog maybe, my mopar never!"
Just got me wondering!
RacerHog May 30, 2016 10:51 AM
You been spending way too much time over on "Yellow Bullet" Getting eat'en.....:laugh:
Jose>>>> Might even check with Performance Gear.... :)
http://performance-gearing.com/
TVLynn Jun 1, 2016 05:58 PM
Going from a 2.83 to a 3.55 May ?? require a new ring gear carrier
josehf34 Jun 13, 2016 10:33 PM
I finished this job the past week, my rear end is a chrysler 8.25 but the real problem was into the installation kit I bought
If someone is planning to do this job be careful and stay away of this kit: https://www.summitracing.com/int/par...rskt/overview/
Both carrier bearings and inner pinion bearing are wrong for chrysler 8.25, don't waste your money!
The excel pinion and ring works great, the car response is a LOT better but I'm still a bit disappointed, my car isn't still burning rubber launching at wot in first gear :(
RacerHog Jun 14, 2016 09:26 AM
How did that go so wrong? Wow... That blows.... :yikes:
TVLynn Jun 14, 2016 10:15 AM
Just changing the gear ratio will not make it a tire burner. A 74 has a smog motor low performance engine. what size tires are you using ?
josehf34 Jun 14, 2016 11:26 AM
My tires are 235/60R15 and the motor isn't stock. Right now I have large tube headers, Air Gap aluminum intake, Street Demon 625CFM carb and 262H XE Comp Cams camshaft
I was loosing my mind with that problem so I took the carrier, pinion and the kit to a local shop and once the owner saw the problem went to back of the store and came back with the correct bearings. I don't know how a kit could be so wrong in so many parts!
TVLynn Jan 1, 2017 12:30 AM
You probably need a different torque converter 2800-3000 stall
