Help: Determine transmission
The codes should be stamped on the driver side of the transmission (assuming it's installed) just above where the transmission pan mounts to the transmission. So, to further explain, the numbers should be just below where the linkage connects to the transmission. It's a lot easier to clean the area off to see the numbers if the transmission is out of the car. Normally there's fluid, dirt, grime in the area and a thorough cleaning should unveil the numbers.
blue 68 gts
Apr 9, 2009 02:06 AM
