Help - Strange Noise, Humming, Roar Chrysler 300
Does anyone know what this noise is in my Video?
2006 Chrysler 300 SRT8 Stock 70,000 miles |
Strange Noise
I am having what sounds like the same strange sound with my 2017 300S. It's like blowing across a bottle. Did you ever figure out what was causing it?
Sounds like a vacuum door in the heat/ac system.
Maybe a bad Door Seal ?
Thanks for the ideas, guys. Nothing I do with the HVAC system makes any difference in the sound ( fan speed, air source, temp, etc) so I think I can eliminate that. All door seals look good ( only have 33,00 miles on car) so I'll keep looking. Strangely, sometimes when I make a turn the sound goes away. When it's making the sound (intermittent) I can make it temporarily louder by yanking the wheel to the left or right. Still seems like a wind noise but darned if I can figure it out.
That sounds more like a Wheel Hub Bearing to me !! :)
I agree, because of the way the sound is affected when the wheel is slightly yanked to the left but not the right. Sounds like the right front hub to me but it's going to have to get a lot louder and more often before I get serious about guessing at a $200 plus wheel hub. Seems like 33,000 miles would be a bit premature for a wheel bearing failure. I just had the wheels balanced and rotated and asked them if they could detect anything and they couldn't.
Thanks for all the help, guys. I'll let you know when I find out for sure. |
Check with the dealer and see if they have a recall on them? Maybe get it done under warranty? :)
