Humming at highway speeds
Old Sep 29, 2019 | 11:59 AM
My72D100's Avatar
I been trying to track this humming sound down, I notice it when cruising at highway speed. The humming goes away when I take my foot off the gas. My next approach is replacing the center carrier support and U joints the truck is a 72 d100 318 with a 3 speed trains. All my fluids are topped off and fresh. Anyone might know what it could be?
Old Sep 29, 2019 | 12:41 PM
Drag Pak's Avatar
Low tire pressure in one tire?
Old Sep 29, 2019 | 12:53 PM
My72D100's Avatar
I checked the tire pressure awhile back. Im hoping it's the center carrier support bearing
Old Sep 29, 2019 | 04:19 PM
I think you're on the right track....
Old Sep 29, 2019 | 05:12 PM
My72D100's Avatar
I'm just hoping it not the pinion bearing
Old Sep 29, 2019 | 05:26 PM
See if the pinion nut is tight......
You will need to drop the drive shaft and if it is lose pull it off and clean up all threads on the pinion and nut with break kleen then put it back together with red lock tight........ You should actually replace the nut but try this first.
Old Sep 30, 2019 | 09:55 AM
iowan has it right!
qman
Jan 1, 2015 09:07 AM
moe7404
Feb 2, 2014 10:40 AM
mooregw
Dec 23, 2011 01:35 PM
olibass1
Apr 22, 2011 03:21 PM
adamst56
Feb 26, 2011 10:29 AM
