Need Help with Pistol Grip shifter! A833!
Hey guys, if you read my other thread the reverse rod on my shifter broke. Well I took it out welded the rod back together and put it back together. When I took the shifter apart I was very careful to take each shim and rod or linkage plate whatever you want to call it off and laid them on the table to where I would know exactly how they came apart. Well I guess as I had my hood down welding my little brother was curious about the parts of the shifter and decided to pick a couple or all (I dont know) of them up and look at them therefore ruining my "perfect order" lol. After trying to guess how it went back together and getting it back in the car I have found all gears work great 1 through 4. But its as if there is not notch in the shifter for it to go up and over into reverse! lol. So I am really needing a schematic or something showing exactly how the shims and plates go together. I would REALLY REALLY appreciate some help here guys other wise I'm gonna have to find someone that knows how it goes together which i'm sure wont be an easy task if not impossible in my area. Or just buy a new shifter which I really dont want to do after seeing the prices on a pistol grip set up! Plz help. Thank you. I have searched google images for a schematic with no luck. Maybe one of you have gotten a part for a pistol grip with directions showing how it goes together?
http://repairguide.autozone.com/znet...528007ff3b.jpg
To mock up a linkage ( especially on a swap or custom application ) the easiest way I do it is to remove the offending rod and measure the placement of the shifter and arm when the arms are in the appropriate sequence for the gear desired without the rod in place. You have to measure on all three axis as it a 1-2mm can keep the action from operating. When you reinstall the rod then make sure the arm and shifter are in that pre determined place. If you welded and removed / added metal or changed the angle than you need to redo the OE setting. If you are just counting threads it wont work. So start from scratch on the mock up and don't use your original data to re install the rod. |
If I remember right, the shifters are Hurst shifters, Competition Plus maybe? Maybe a Comp Plus without the stops etc... Hurst offers a rebuild service for OEM shifters...
Originally Posted by PK1
(Post 93199)
Originally Posted by MrOldart2U
(Post 93209)
i did do some hunting around for any kind of diagram but i too came up empty....
There were some shifter rebuild articles in the Mopar Action Magazine Aug 95 and 97 ? If you can find a copy
Maybe these?
(Post 93289)
Have ran across a thread on a different make forum that shows the rebuild process also, If needed I'll post the link....
i thought i saw one for sale here on the forum
Hi, I need the driver's and passenger's side rear window crank handles. The rears are a bit shorter than the fronts to clear the inner quarter panels.
Hmm, I thought this post was dealing with a pistol grip shifter?
| All times are GMT -7. The time now is 02:40 AM. |
