neutral safety/ reverse switch
Old Mar 4, 2013 | 04:27 AM
69Ronrunner's Avatar
Dose any one know if a three prong neutral safety /reverse switch is the same size or can replace a single prong neutral safety switch in a 727 torqueflite?
Can a 69 wiper be put on a 68 detent leaver to make the 3 prong switch work properly for reverse lights??
Old Mar 4, 2013 | 07:44 PM
jacilynn_s's Avatar
Will it fit in the case. Yes. Will it work? No. The shifter arm on the valve body is slightly different and wont touch the switch.
Old Mar 4, 2013 | 09:14 PM
I've been told that the 3 terminal switch will replace the 1 terminal switch for NSS, but will not work for reverse lights. Have not actually done this.
Old Mar 4, 2013 | 09:58 PM
Moparod's Avatar
The single terminal NSS went bad on the 727 in my '68 Charger and I swapped it with a 3 terminal, worked just fine. The 68 backup light switch is mounted to the column- mine had a column shift, I'm not sure about the '69. If I remember right you use the center terminal on the 3 prong.
Arbiter343GS
Oct 31, 2011 08:44 AM
Aaron.Albrecht
Jul 30, 2011 10:24 AM
Derek77PW
Jul 16, 2011 08:33 AM
Dave MoorePower
Aug 11, 2008 05:59 AM
hemihead
Mar 18, 2008 03:23 PM
