No drive in any 727 trans position after Transgo install
Old 07-22-2018, 11:44 AM
droptail's Avatar
Drove around the block - felt like it went into neutral and quickly popped back into gear couple of times - and overlap in Drive - forgot what gears.
Then when I put it in reverse to back into garage I lost all trans engagement - nothing.
It does show 1pt low - which I doubt would cause the control?
The overlap is band adjustment I assume.
I'm not blaming Transgo - I'm sure it is something I screwed up in the process of doing the kit.
Any ideas?
Thanks
Old 07-22-2018, 11:58 AM
I'd say it's time to go back over the installation mabe pull it apart and make sure you did everything called for. 🙂
Old 07-23-2018, 08:34 PM
Take the trans out and go over it carefully.... Might also need a book to help you find it.... Transgo can ge a little hard to understand some times....
One of these first three are good to help you if you need it...
Amazon Amazon
JPR56
03-16-2020 07:59 PM
inri
08-25-2019 07:21 AM
78cordoba
04-22-2010 03:04 AM
anthony oborny
01-10-2010 06:16 PM
anthony oborny
01-10-2010 06:06 PM
Quick Reply: No drive in any 727 trans position after Transgo install
