Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   screw of 40pin connector on TCM 4606105 won't come off (https://moparforums.com/forums/f82/screw-40pin-connector-tcm-4606105-wont-come-off-14766/)
ttoaster Apr 28, 2013 01:40 PM
Hello,
I have a 2.4L 4cyl dodge stratus 1995 with a 4606105 TCM. I want to take the 40 pin connector off, but I keep turning the main retaining screw and nothing happens. Has this ever happened before? How can I get the connector off?
Frank
Coronet 500 Apr 28, 2013 04:40 PM
I have had the cast in nut break and turn freely on the end of the screw. All I can suggest is give the connector a tug.
ttoaster Apr 28, 2013 07:41 PM
Thanks! That sounds plausible. It looks as if somebody that had worked on my car had encountered this issue because the plastic covering the wires on the end is broken off. I will try pulling on the screw head directly, maybe I will cut off.
I had two garages replace the speed sensors before and now there's a code for solenoid pack too. I'm guessing there's a bad connection, or the computer itself is bad. I bought off a scrap dealer a TCM that I was hoping to put in today until I couldn't get the connector off the TCM in the car.
Frank
