Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   Strongest 7.25 ring and pinion? (https://moparforums.com/forums/f82/strongest-7-25-ring-pinion-24854/)
808mopar Dec 3, 2022 04:27 PM
No scrap yards on my island and shipping from the mainland is very expensive. Please don't recommend a bigger unit, right now that is not really what i want to do. Hope someone can point out the strongest gear set.
Iowan Dec 3, 2022 08:27 PM
While not having hands on experience with the 7.25 Chysler axle other than removing for a swap. I do have experience with the Ford 8" and 7.5". From what I have seen if I was looking for strength I would go with a 3.25 gear for performance gear based on the pinion size a ring gear thickness but the pinion bearing size is probably it's weak link.
I hope this is what you are looking for.
808mopar Dec 4, 2022 12:00 AM
Thank you for the reply. A 3.55 is stronger than a 4.10? Because the pinion is bigger?
Iowan Dec 4, 2022 09:03 AM
The pinion gear diameter is larger on a 3.55 than it is on a 4.10, it is on every gear set no matter what axle. The problem is problem is the parts are getting tiny on a 7.25 axle.
808mopar Dec 5, 2022 01:57 AM
Thank you for the help.
