Swap 904 transmission
Check out my post "Big time swap" some good tips in there
The a 500 should be none electric the A. E .series have a electric selonoid for overdrive the other issues will be size the overdrive tranies are longer and wider at the tail shaft.
which meens the trany mount , cross member and drve shaft/ trani tunnel will also need modifications .
I did the swap with no major shop or tools yoi will need metel fab equipment though ...welder cuter and the such.
it was worth it for myself best swap I have done to date.
cudaracer
Sep 26, 2011 02:43 AM
jerzjer
Apr 29, 2011 03:02 PM
