Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   TF727 filter change, how many fluid? (https://moparforums.com/forums/f82/tf727-filter-change-how-many-fluid-19369/)
josehf34 Apr 22, 2016 04:00 PM
I'm going to change my TF727 filter and gasket but I'm not sure how many hydraulic fluid should I add after doing this job or if is necessary to drain converter and transmission completely before doing this job
schreddr Apr 24, 2016 10:15 PM
OMG. I just wrote a step by step tranny change.. And they logged me out before I could post it for you.. If no one else replies let me know. Done lots. It's easy but no you can't get all the fluid out of the converter unless it has a drain plug..??? Or you take it off and turn it upside down and shake the crap out of it.. Let me know if you need more detail.. Gonna post this before I get booted again. Happy motoring.
RacerHog Apr 25, 2016 11:08 AM
You can just service the pan if you don't have a flush machine available....
Schreddr... If it dose that to you... Finish typing and just scroll down and long back in.... It should auto post after that.....
TVLynn Apr 25, 2016 01:39 PM
Change the shifter shaft seal and the dip stick O ring, speedo O ring too...
