Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   tq converter 2000 stall (https://moparforums.com/forums/f82/tq-converter-2000-stall-13762/)
85dodgeram350 Nov 21, 2012 05:56 AM
i have a a518 bolted to a built 360 with airgap intake stock heads comp cam 268h cam 670 streetavenger carb i am wanting to no if a 2000 stall will help with my launch and doing burnouts scinse the cam said best use is with a 2000 to 2200 stall
Gorts 5th Nov 21, 2012 06:18 AM
yea you can do burnouts.
the weight of the vehicle matters also, but it you want to sit and spin your off in the right direction.
i used that same came in my previous engine comp has nice cams.
85dodgeram350 Nov 21, 2012 02:51 PM
its in an 85 dodge ram and i also thought i needed one because at stop lights it wants to push a little bit and i had to turn the idle up so when i put in in gear the rpms dont go to low
Gorts 5th Nov 21, 2012 03:12 PM
your cam should idle with a low stall converter maybe you got to much initial advance on your timing.
how are you in-gauging the lock up converter and overdrive
are you using switches and relays or some other set up?
if your converter is locked up in gear you will have it trying to push through any stop and its going to burn up if you keep running it with a in-gauged lock up, you have to fix that issue its not supposed to be locked up until u activate it. Give me more info.
85dodgeram350 Nov 22, 2012 08:23 PM
ok and i dont have lock up just overdrive to ingauge the od i just ran a wire from the shift solenoid to a switch so i just flip the switch when i need od i did feel like dealing with all the switches i just wanted it simple
Gorts 5th Nov 23, 2012 06:32 AM
OK i'm assuming then that your 518 is a none lock up style you only have 2 pins at the electrical hook up is this correct?
and your not running a lock up converter but a standard low stall converter?
your motor should still idle in gear i had that same cam and in your motor size should be slightly noticeable that is the idle should be fairly smooth
i think your initial timing is to far advanced
try backing it off.................duration lift
the specs on that cam are 268 268 454 454, 1500-5500 rpm.
when you run down the road does she "pop" out the tail pipe? that's a good sign that the timing is too far advanced.
What type of distributor are you running on her?
on the carb are you using the programmed vacuum port or the none programmed vacuum port for your vacuum advance? also you may have to do more adjustments on the idle using the air fuel mix screws what size power valve is in that carb also?
i would use the programmed port and back off my initial timing and then use lighter advance springs/ heaver advance weights for a faster advance curve. in gear she should idle around that 800 rpm mark and there is always some "push"
85dodgeram350 Nov 23, 2012 08:55 PM
im sorry that is not the right cam the cam is XE268H duration int 268 exh 280 lift int 477 exh 480 is the specs of the cam the comp cam says works best with 2000 stall and the tranny is non lock up and it doesnt pop when cruising down the road it runs great it has the stock distributor and i dont know about the vacum port on the carb
