Mopar Forums (/forums/)
-   Transmissions, Transfer Cases and Rear Ends (https://moparforums.com/forums/f82/)
-   -   trans problem (https://moparforums.com/forums/f82/trans-problem-16040/)
BA440-78PU Oct 20, 2013 11:50 AM
trans problem
I have an 04 1500 it has the 4 wheel drive shift switch instead of the shift leaver on the floor.When it rains it shifts into 4 high on its own.I've always been able to get it out and back into 2 wheel drive until the other day it rained and it did it again but this time I can't get it out.Has anyone else had this problem and does anyone have any suggestions on what could be causing this problem.
TVLynn Oct 20, 2013 12:58 PM
Check the wiring to the trans, clean the connections and coat with dielectric grease
