To turn ESP off
Hello, I have a 2015 Charger SE and I live in sunny CA I see no use for the ESP and would like to turn it fully off I know the button only turns it some what off but I have no use for it at all how can I fully turn it off? |
Also I have tried to hold the button down trick doesn't work...and I have a keyless ignition so the key trick doesn't work either....
Is there a fuse you could pull? I honestly don't know, the ESP button in my '09 Journey seems to kill the entire traction control. It blazes both front tires indefinitely at will
I think you have to go into some of these and turn them off with a scan tool..
I'm not too sure but i think it was on this site one of our members figured it out on a Charger or a Challenger????? Not 100% sure, but I think he used a scanner to turn it off? |
I heard thair is a fuse I can pull but then I'm afraid of getting error codes in my computer..
CHRYSLER 300 2013 ISSUE WITH VIDEO (WHEEL & AROUND)
In the Search box type "Turn Off ESP" and hit search... Find the above and see if that works for the 2015... :) |
couldn't find any thing, its silly they think I can't decide for myself If I need it on or off :(
| All times are GMT -7. The time now is 05:35 AM. |
